A99V boots in manual focus mode
JohnLarsenV
My a99V has recently begun to boot in Manual Focus mode.
I do not believe I have changed any settings.
Manual and Auto focus mode both functions OK.
So do everything else as far as I have found out.
Can anyone please give me a hint how to fix this annoying issue
Sean_Mc
Moderator
Hi John,
Let me look into this and I will update the thread when I have an answer for you.
Best wishes,
Sean
IamNic
Hello @JohnLarsenV,
usually both the camera body and the lens have a mechanical switch where you can disable auto-focus.
Check if these switches are set to "AF".
- Nic
The_Black_Rose
Specialist
Hi JohnLarsenV,
I totally agree with IamNic. If it's not the actual switch, I'd say reset the camera to the factory settings. The steps are on page 47 of the manual: https://www.sony.co.uk/electronics/support/res/manuals/4436/44362471M.pdf
Cheers,
The_Black_Rose
