AF-D lens compatibility
Sarah1122
Hello,
I am thinking about the possibility of a new lens but cannot find within the technical spec information as to whether the lenses are compatible with AF-D. I've also tried dyxum but cannot find all Sony lenses listed on their database.
Has anyone had success in finding this information? Help would be appreciated. Thanks.
Sarah1122
I found it eventually.
Support tab / type in camera model Result compatibility of lenses and accessories.
Sarah1122
