Solved! Go to Solution.
I'd say to send it into to Sony for service.
or if you have any extended warranty maybe look at using that.
Mark.
Mark.
Hi @gnlynbrlt and welcome to the Community
It sounds like the camera needs a hardware repair,
so you're best giving Sony Support a ring.
Does this message occur with other lenses attached?
(I guess you've tried removing the battery etc. too)
