I have a Sony DSC-H50 and am thinking of moving on to a DSLR. I am really impressed with the Auto Focus abilities of the H50 so want a DSLR to have the same system or better. Can anybody tell me if the Sony DSLRs are as good if not better? (I take a lot of pictures of R/C aircraft in flight). Thanks.
Another RC addict! Glad I am not alone. Welcome to the Community.
What sort of scale do you normally photograph? I try to photograph RC cars all the time and I have to tell you, it is not as easy as I thought. You need far more practice than I anticipated.
I would say any of the current Alpha DSLR's would be up for the job but what you want is something with a high frame rate so you can fire off a good burst of shots. That way you can have a look at what is worth keeping plus makes some nice sequence shots.
Where it gets difficult is the focusing itself. You might be a natural but at first, I would it very difficult getting any photos that were worth keeping because I was not used to the changes. Shortly after, I found that moving to a DSLR really improved the quality of the photos because I had more control over what I wanted to capture and I think you will too. A shot like the one I took below would have been very difficult to capture on anything other than a DSLR.
Im heading to our race track in Nothampton on Wedsnesday with a A58 and a few lenses to see how I have been getting on with my practice so maybe I can give you a better insight at that point since its been a while. Honestly, moving to a DSLR especially for RC stuff is the right way forward.
Please do share some of your photos.
Thanks for your reply. I appreciate what you are saying about the DSLR but I am really trying to address the question to the Sony Technical people, but I don't seem to be having any luck targeting them! I have great faith, with results to support that, in the systems in this camera but I also know that newer products are not always superior products. I would just like to confirm the AUTO focus technology in the DSLRs.
I take pictures of friends R/C planes in flight, scale - not sure, but wingspan from 1/2 meter for small jets to 2 or 3 meters for large scale. I am happy with the single shutter shots right now as I am pretty good at following the aircraft or anticipating their location through the viewfinder. The auto systems are so good that I usually have some quality shots to keep, maybe 1 out of every 10. Not a bad ratio I feel. In most cases if the focus will "lock on" then the picture will be acceptable.
I hope I have attached a few shots as examples for you. All reduced down to about 50k so I don't know what the quality will be like.
All the best DD
