Battery grip fit
ladylarch
Battery grip fit
How does the battery grip fit the Alpha a77 and what happens to the existing battery cover
Mick2011
Hi ladyarch :slight_smile:
It screws into the tripod mount on the bottom of the camera using an integrated knurled knob. Fits very solidly, feels very much part of the camera once in place.
There's a slot inside the battery grip body that the opened A77's battery cover sits in.
Mick
Mick2011
Mick
ladylarch
Thank you for your help
Mick2011
You're most welcome :cool:
