I am looking for a suitable battery grip for my SONY A 290 have seen some on AMAZON but non seem to be compatable with the 290
Solved! Go to Solution.
Hi cjkilburn12
Unfortunately, the A290 is not compatible with any Sony Battery Grip.
Have a look at this link: -
http://esupport.sony.com/US/perl/support-info.pl?template=&info_id=637
Hi cjkilburn12
Hi Blencogo
Seems that as you say their are no Sony grips for the 290, Does any body know of any non branded grips that would work with the 290
