Can I get a replacement hard/paper copy Instruction Manual for my DSLR-A200 camera?
Solved! Go to Solution.
I think that may be a difficult task as this model is no longer current.
I would download the full 160 page user manual as a PDF from here: -
ftp://ftp.vaio-link.com/pub/manuals/consumer/DSLRA200EN.pdf
You can then print this "as a leaflet" using the Adobe Printing Options - you will need to turn the paper over half way to print on both sides of the paper.
