can i usr a cobra 700AF-Mi on my A68
IDUNWORKING
can I use a cobra 700AF-Mi on my a68 with a ADP-MAA Hot Shoe
4 REPLIES 4
Pascale_F
Moderator
Hi IDUNWORKING
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi IDUNWORKING,
I'm not really sure that this will work as this is not listed as a compatible device on Sony's website: https://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=gb&lang=en&mdl=ILCA...
Cheers,
The_Black_Rose
IDUNWORKING
Hi thanks for the link  have had a look and u are correct about it not being in the list
but it has the same connection as a lot of the old flash units. I used this on my
Minolta dynax 700si film camera it will fit on the a68 with the adapter but my
concern is if it will brick my camera
The_Black_Rose
Specialist
Hi IDUNWORKING,
Since Sony didn't mention that both devices are fully compatible, I am afraid that the fully functionality cannot be really guaranteed.
But if you've both devices, just test them and let me know how did it go.
Cheers,
The_Black_Rose
