Can't install Nex 6 Software
Dufocus
My Nex-6 Came with the usual disk containing the RAW converter, but it will not install on my older (Power PC) MAC pro. I cannot install Lightroom (preferred option) as the later versions are not compatible with Power PC Macs, and the earlier versions do not support the NEX-6. I have the earlier V3 Image Data Converter from my previous NEX-5, but it will not recognise the images from my NEX-6. Does anyone have any suggestions?
0 REPLIES 0
