Digital level gauge
ChrisWM
Digital level gauge
Hi!
I recently purchased an a6300 which I am very pleased with, although I wish I had known about the a6400 which was released around two weeks later.
An issue I have is with the level gauge which to me seems to be quite insensitive as I have taken several photos and as examples a monument leant to the left in one picture and then to the right in another.  In another, a house also leant.
The lens used is the SEL18200LE
I have found elsewhere on the site that a discepancy of +/- 1º is apparently normal.(https://www.sony.co.uk/electronics/support/articles/00014661 ).  Does anyone have any workaround for this as it appears to be worse than stated?
Chris
IamNic
Hello @ChrisWM,
would you mind uploading one or two example-images where the "lean" is visible?
- Nic
ChrisWM
Hi Nic
Thanks for the reply.
As requested here are three examples. Thanks for your input. Regards Chris
IamNic
Hello @ChrisWM,
thank you for uploading the pictures.
The angle seems to be so far off, that in my opinion that is not inside the expected tolerance.
Since I couldn't find any option to calibrate the level-meter, it may be best to either send the camera in for repair or if you just bought it exchange it for a new model.
- Nic
