I have varying opinions on whether I need a ring mount for this heavy lens while using it on a tripod with my a6500. Can anyone please give me advice as I have been told that I need the novaflex astat-nex and at £75 I don't want to make a costly mistake if I don't need it.
Don't think that you need an additional ring mount. Usually a ring mount is supplied when needed e.g. https://www.sony.co.uk/electronics/camera-lenses/sel70200g.
In addition I guess that there's not much room on the 70300 lens where you can attach a ring mount.
PD
