Does Minolta Program Flash 5600(HS) function together with Sony DSL a580?
profile.country.sv_SE.title
roswed
Yes it does.
The following Minolta flashes are fully compatible with Sony Alpha in auto mode: -
3600HS (D), 5600HS (D), 2500(D), MACRO RING FLASH1200, MACRO TWIN FLASH2400.
The following flashes can be used but may not be controlled automatically:
5400HS, 5400Xi, 3500Xi, 2000Xi, 5200i, 3200i, 2000i, 4000AF(*), 2800AF(*), 1800AF(*).
*Flash shoe adapter FS-1100 is required.
:wink:
Yes it does.
:wink:
