I dont use adobe and I cant find a software package to edit .AWR files taken on SONY A7R3. Tried COREL Aftershot doesnt support. Any ideas please
Hello @owratcl79,
I can highly recommend "Affinity Photo", it is quite inexpensive and works with all Sony-camera RAW formats
They have a free test version as far as I know, so you can check it out.
- Nic
In addition to Affinity (which is more of a Photoshop alternative than Lightroom) you can try ON1 Photo Raw 2019.5.
it is much more like Lightroom with the ability to import lots of photos from a shoot, cull, grade, sort, keyword photos, then develop and apply various filters and presets too as well, it also does layers if you want to do simple composites.
i use ON1 and then send them to affinity if I have a complex composite.
you will need a powerful machine for ON1 though with the size of the files from your camera!
I suggest you try the 30 day trial, plenty of tutorials on YouTube to help you out.
