Focus Point - A7ii and A6300
A65Woodley
I am using both a Sony A7ii and a Sony A6300.  One of the things I really like about the new A6300 is that when I'm about to take a picture the wheel on the back is already (by default) actively controlling my focus point without me needing to select anything.  Does anyone know how I can set my A7ii to behave in the same way?   Thanks
Thalamus.
Champion
Hi A65Woodley,
there is the option to assign custom settings to a number of keys on the a7ii buy pressing menu the selecting the Cog then select Custom Settings > Custom keys settings..
Depending on the option you require you could assign one of the buttons to focus area..
