Hi. I have an a5100 which I would like to control via a laptop/tablet/smartphone (any of them would do!), and be able to enlarge the image I see to get the focus really crisp. But Sony choose not to make that possible as far as I can see. I can get live view through my smartphone and Imaging Edge software but can't see how to enlarge the image so it just stays fixed and about the same size as on the camera screen. Does anyone know if it is in fact possible to get a live view I can zoom in on using Sony software, or if not by using other manufacturers' products? Thanks for any help.
Hi there,
If you get in touch with the support team here they will be able to advise you about this further.
Best wishes,
Sean
