Image Data Converter version 4.0 HANGING
andyemp
Hi
IDCver.4.0 keeps hanging when the green progress bar reaches 90-99%.This happens after processing varying numbers of SLT_A57 arw files (could be on 1st operation or after 10 file converions).Any suggestions as to why this keeps occuring?
Tags (1)
andyemp
Hi Mick
Thanks for your reply, unfortunateley my system( windows 7 & NVIDIA Geforce 9200) will not allow me to switch off the hardware acceleration as suggested but on telling a friends son what you had said he suggested that if I ran Image Data Converter in compatability mode(windows xp service pack 3) it would have much the same effect. I have tried this and it appears to work. So thanks to your suggestion I appear to have found a workable solution.
Andy
Mick2011
Hi andyemp, welcome to the Sony Forums :slight_smile:
This sort of thing is usually a computer hardware acceration issue. Have you tried switching hardware acceleration off?
Mick
andyemp
Hi Mick
Andy
Mick2011
That's great Andy, thanks for letting us know you got a result :cool:
Mick
