SONY''A200 - QUALITY SET TO FINE - RESULTS CAN BE AS LOW AS 2592X1944 - NEVER ABOVE 2900. WHY, PLEASE?
Jay
Solved! Go to Solution.
Hi Jay and welcome.
I assume you are shooting JPEGs?
In addition to the Image Quality, you need to set the Image Size to "Large" to get up to 3872 x 2592. Perhaps the Image Size is set to "Medium" at a maximum of 2896 x 1936.
To change the Image Size
MENU button - > Camera 1 -> [Image Size]
Have a look in your manual on Page 106. You can download the Manual here: -
http://pdf.crse.com/manuals/3277950151.pdf
Hi Jay and welcome.
