Hi, I have just downloaded Imaging Edge onto a Windows 11 pc. The Viewer window crashes after a couple of seconds, the Edit window is fine. I uninstalled and reloaded the software but it made no difference. Can anyone suggest what the problem may be and what I can do about it? Any help appreciated! Regards Rob
