Imaging Edge
profile.country.DK.title
Ricmo1
Imaging Edge
Is Remote Shooting using Imaging Edge not supported in Denmark?
I would like to view the picture from a Alpha 7II on an Mac computer screen (with version Os 10.11.6 software) before taking the picture.
iancandler
It should work fine, connect the USB lead to your camera then in settings/toolbox set it so its on PC REMOTE, then start the remote software
