Lighting
nic2017
Lighting
Hi does anyone know if you can use external studio lights with the Sony NEX-5N and if so what lights? Many Thanks
jumpsuit
Hi again @nic2017
Yes you can use external lights with the NEX-5N:slight_smile:
Here's an example of an adaptor that can control studio lights wirelessly
http://www.scottlewisphotography.eu/?p=3168
with a list of supported flashes too at the bottom.
Hope this helps.
4 REPLIES 4
jumpsuit
Hi @nic2017 and welcome to the Community :slight_smile:
I'm just going to double check for you.
I'll post back here later :slight_smile:
jumpsuit
Hi again @nic2017
Hope this helps.
nic2017
Hi thank you very much for your help. Can you use camera lights externally without a light meter or do you think they should be connected to the camera and a light meter used? I am hoping to so some location shots of beauty products. Thank you
jumpsuit
Hi again
You're welcome :slight_smile:
I don't think this adapter supports TTL so you may be better with a light meter.
As its not Sony and I haven't used one, it may be best for you to get in touch
with the manufacturer just to check.
