Low Fps on recording movies with Sony A37
profile.country.pt_PT.title
zmp2000
HI, I have a Sony A37
The specifications says it can record movies with a resolution of 1080i at 60FPS
But, when I access the properties of the file generated by the camera, I can see only 29fps on specifications. What´s wrong?
profile.country.de_DE.title
cmosse
Actually the camera reads out the sensor with 30p (29.97) but then splits each of this frames into two identical fields to generate a standard 60i output, (a technique which is called progressive segmented frame).
There is nothing wrong with your camera.
