Hi all,
i'd like to get a new SD card for the a5000. Any idea what is the maximum capacity it can handle?
Ideally i'd like to get 256gb but don't know if it will be supported?
Thanks,
S
Solved! Go to Solution.
Hello @gsofov,
according to the manual it supports SDXC cards - it doesn't specify a maximum size limit.
So I would say it should support a 256GB SDXC card.
- Nic
Hello @gsofov,
- Nic
