Hi morten56 and welcome.
It should take a SDHC Card OK. What make of card are you using?
I presume it is inserted correctly?
Have you got an old SD card to try to check the slot is working OK?
I am having the same problem with aSanDisk card/the same model! Did you find one that works yet? I need to order a new one...
