New Sony E 18-135mm and NEX-6 camera?
StephenOne
Hello,
Does anyone know if the new Sony E 18-135mm F3.5-5.6 APS-C zoom lens to be released on the 19th February 2018 will be suitable for my rather dated Sony NEX-6 camera? Will I need a firmware update?
Many thanks.
Sean_Mc
Moderator
Hi Stephen,
I would recommend getting in touch with Sony Support for further advice on this.
Thanks,
Sean Mc
StephenOne
Hello,
I received the following reply from Sony re. my enquiry if the new 18-135mm zoom would be suitable for my NEX-6.  A firmware update is available for the A6300 and A6500 cameras.  I am doubtful that an update will be made available for the NEX-6, which is disappointing as I definitely would have bought the new lens.
"Thank you for contacting Sony support.
With reference to your enquiry regarding new lens release compatibility.
We are sorry to inform you that the dedicated team has not communicated us this information yet. You may check the below link for updates:
https://www.sony.co.uk/
Should you have any further questions, please feel free to reply to this email.
Thank you for your enquiry."
