hi guy i need a SQAURE lens hood for nex 5
any ideas that will fit direct onto 18-55 mm kits lens
or a cheap mattebox but must be small
I LIKE TO KEEP IT COMPACT
help plx #
thx abdul
Hi Abdul,
Do you mean square or will rectangular do?
I think you will have to Google for a square 49mm snap-on lens hood.
Hama and Pentax do make compact rectangular ones.
