Hi Folks
Have just reinstalled XP Home and find videos wont play. Can see them in PMB but when I try to play I get a black screen with an "S" in the middle.
Telephonrd Tech Support but they refused to help me.
Reloaded PMB, downloaded the 165MB Uodater file (!) AND the MS SONY - WindowsXP-KB932716-v2-x86-ENU. Still nothing.
Anyone got any suggestions because I will sell my camera if Sony won't support their software.
pvg2011
Solved! Go to Solution.
Hi
try download VLC
and see if that works that will tell you if the problem is with xp.
Hope this helps
Niall
Hi
try download VLC
Hope this helps
Niall
