Registering FX3 doesn't work
ommo88
I'm trying to register my FX3. But it won't do. Doesn't show up in any of the lists as well.
Tags (2)
Peter_S.
Genius
I had no issues to find the FX3 in the list:
So maybe try again - maybe it wasn't listed when you've tried.
Peter
Joe_Dohn
Specialist
Try entering the model number as "ILME-FX" (without quotes) and just pick FX3 from the list.
You can also use this handy link (courtesy of Sony support).
Hope this helps!
- JD
