Replacement Eyecup for Alpha 55
almacke96
I should have known better after the loose fitting rubber eyecup on my A100, which I used some light adhesive to keep on - the one on my new A55 has dropped off and disappeared already after just three days !    I cannot find a replacement part listed anywhere on the Sony site, or with any other vendors (Amazon have them for earlier models but too big for the 55)
Can anyone help with a contact ?   Many thanks
Thalamus.
Champion
Hi almacke96,
welcome to Questions & Answers..:smileyhappy:
The part number for the Replacement Eyecup for your A55 is X25144421.
You should be able to order this from either your local Sony Centre or an independent camera retailer.
Alternatively you should be to order the part from Sony's dedicated spare parts provider Nedis
Thalamus.
Champion
Hi almacke96,
almacke96
Very many thanks. Sony Centre said that there wern't any available as yet - waiting on spares arriving in the UK apparently-  but I'll give the other contact a try. . Might just have to percevere without one for a month or so.
cheers
AMac
Thalamus.
Champion
If you don't have any luck locating the part let us know and we'll see if we can help further..:smileyhappy:
