I have accidentally deleted photos from my sony memory card, is there any way of retrieving them? Help
Solved! Go to Solution.
Hello JennyMac79 - welcome to the Sony Forums.
Sony offer a free download of their own Memory Card recovery which can be found here:
http://www.sony.co.uk/hub/memory-cards-usb-drives/10/1
It will locate files that have been deleted nine times out of ten so you have a reasonable good chance!
Good luck,
Simon
Good luck,
Simon
I'm having the same problem but all suggestions above are not free.
You can use Sony data recovery software to recover data from Sony memory card, see this guide: Recover data from Sony memory card
helped me before.
Hi “Jackhilfuer”
Don’t forget!
You must not use this memory card to write new files, before using Memory Card recovery software!
New files could overwrite old deleted files. In that case it’s impossible to recovery files.
Jannis
PS
Here’s a direct link for: Memory Card File Rescue
| Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
