SAL14TC jammed on lens
michaelsunny
Hi
I hope somebody here can help, as Sony customer support hasn't! I sent my SAL14TC in for repair as it had jammed onto my 2.8/70-200 G SSM II lens. It was returned today with the report that no fault was found. I (foolishly) put it onto the lens to check. It released 1st time, but jammed on the 2nd and now won't release. To clarify - it is not jammed onto the camera body, just to the lens. The lens has not shown any sign of sticking/jamming onto the camera body. The SAL14TC will not retract the locking pins. Phoned the repair centre immediately - no help and no engineers available as they finish at 12 on a Friday! I'm stuck. Cross. Frustrated. Any ideas ?
7 REPLIES 7
jumpsuit
Hi @michaelsunny and welcome to the Community :slight_smile:
Have you contacted Sony Support again about this?
(I wasn't clear which repair centre you contacted today)
As the problem sounds mechanical, I don't think there is a quick, easy fix for you.
Do you have a case number from Support that I can use to escalate this for you further?
michaelsunny
I have spoken to the repair centre in Pencoed as well as Customer Support today - neither of which could offer a solution.
The case number is 16258478 and the repair job ref is 647505.
I know that it is a mechanical issue - that's why it was sent for repair originally.
Any help would be gratefully recieved as I am losing the will with Sony.
jumpsuit
Thanks for the info :beers:
I have escalated this for you but it may take a couple of working days
for someone to contact you.
Are your contact details correct in your profile?
michaelsunny
Thank You
Yes - correct email address in profile
jumpsuit
Hi again
Please include a telephone contact number in your profile (they usually contact
by telephone) plus it will be a quicker way of getting in touch with you.
cheers
michaelsunny
I've been contacted by Customer support as well as Repair centre and received conflicting emails. I will have to send the converter back again, after managing to free it from the lens. Not happy.
jumpsuit
Hi again @michaelsunny
Apologies for not seeing your post sooner.
Please keep us posted on the outcome.
