Small subjects accurate point focus issues
saleeltambe
 I recently moved to A9 +200-600mm +1.4x and finding serious problems quite often with the AF not able to focus precisely on small point like objects against distant backgrounds. My earlier Canon 7D MK II + 500mm f4 + 1.4x, the AF pin-pointing was not as bad as this.
Here is one image attached as an example,119011622_10222965200734249_3576788301838879485_o.jpg
1. where the owl is quite small in the frame and against a tree and the A9+200-600mm+1.4x combination, the AF tends to focus predominantly on the tree in the background which is understandable but there is no way I could aim to spot focus accurately on the bird ahead of it.
2. The AF also freezes if I try to focus quickly from a far away object to a closer objects (say a bird suddenly coming in and seated on a branch just next to me) .
I usually use the "Zone" focus pattern. I even tried the flexible focus point mode (S, M, L) but its much worst than the zone focus.
Appreciate any similar experiences / kind suggestions / pointers please. I have raised this problem to Sony support team, but no satisfactory solution yet.
Peter_S.
Genius
Have you tried to alter the tracking sensitivity?
https://helpguide.sony.net/ilc/1830/v1/en/contents/TP0002384077.html
Peter
saleeltambe
Thanks Peter , I tried many things including the link that you sent but the issue has been still the same.
