Hey guys, I have a trouble with setting a6400 with gimbal weebill. I cannot change USB settings in camera. There ia only USB MASS STORAGE option. I enclose the picture. When I try to change it, there is a message "this operation or setting not available as follows"
Thanks for any advice.
Tom
Hello @eliska6400,
the image you show in the picture has nothing to do with the USB-mode. Unless the camera message means you have to deactivate it to be able to change USB-cconfiguration.
This is the setting you need to alter: https://helpguide.sony.net/ilc/1810/v1/en/contents/TP0002241317.html?search=usb
- Nic
