Hello
I have problem with HSS and TTL on my Sony A7III + hvl-f45rm.
If I set speed for example 1/2000 I have lines on my photo.
With 1/250 is all OK.
If is e-Front Curtain Shut. = OFF, then I can use for example 1/8000 without lines on photos.
Is it OK? Can I not use e-Front Curtain Shut. = ON with HSS?
Or where is the problem?
Thank you.
What is the function of the electronic front curtain shutter?
https://www.sony.co.uk/electronics/support/articles/00018997
Manolo
So, if I use:
Sony A7III + Sony FE 85mm F1.8 + Sony hvl-f45rm + 1/8000 + F1.8 + flash ON
I must turn OFF e-Front Curtain Shut.
Do I understand this correctly?
Peter
Yes, because otherwise the problem of Rolling Shutter presents itself to you.
Manolo
