Sony a7iii - Multiple clicks when pressing shutter
profile.country.GR.title
diapsony
I m having an issue when I press the shutter button once. Instead of that, I take multiple pictures (2 or 3) just like I use continuous shooting mode (which I don't) .
No DRO on, no bracketing, I initialized my camera settings and still the problem continues.
A colleague of mine advised me to attach the speed light that I m using, activate and deactivate Rear sync (which I frequently use) and that seemed to solve the problem for a week. Then the problem appeared again.
I know it s weird, I searched every forum that exists and I cannot find any solution.
Any ideas?
6 REPLIES 6
IamNic
Hello @diapsony,
in which mode are you shooting?
If I recall correctly, in intelligent automatic the camera may shoot multiple images in bad lighting conditions to minimize grain.
- Nic
diapsony
Single shooting mode, and nope.. it happens all day and night long
IamNic
Hello @diapsony,
I still suspect it is a settings matter - have you reset the camera to get it back to factory settings?
- Nic
diapsony
yes I have and it didn't solve the problem.
IamNic
Hello @diapsony,
could you record a short video (with sound) of the camera making this noise with a second camera/smartphone and upload it to YouTube as "not listet" and link it here?
- Nic
diapsony
Nic I will do that as long as I reproduce the problem again. For some reason, I cannot do that the last two days. Thanks again
