Can anyone help please. I have the a7iii and the a7r3 and in movie mode I can change shutter and aperture. I just bought an a9 and the dials are locked. Ive been into the menu settings and locked then unlocked the dials but this hasnt changed anything. all i can change is ISO but the shutter speed and the aperture are locked
your help appreciated
Nick
Solved! Go to Solution.
Yes sorry, my fault... Maybe you have to modify Movie: Exposure Mode
https://helpguide.sony.net/ilc/1650/v1/en/contents/TP0001477949.html
You can set the exposure mode for movie shooting.
Manolo
https://helpguide.sony.net/ilc/1650/v1/en/contents/TP0001454464.html
In [Program Auto] mode when shooting movies, the aperture value and the shutter speed will be set automatically and cannot be changed. For that reason, the shutter speed may become fast in a bright environment, and the motion of the subject may not record smoothly. By changing the exposure mode and adjusting the aperture value and the shutter speed, the motion of the subject can be recorded smoothly.
Manolo
Manolo
Hi Manolo, thanks so much for your help. I wasn’t aware that in movie mode there was the option to set Movie M, Movie S, Movie A and Movie P. My a9 was set to P. I have changed it to M and have full control – Great result !!
Kind Regards,
Nick Sievewright
Commercial Photographer, Videographer & CAA approved drone operator
Edited [personal details removed]
Happy to have been helpful and forgive the first answer.
Manolo
