Hello
I have recently purchased a Sony ICF-CL75iP (photo frame - radio alarm clock), it works with my old IPOD, but not with the latest generation (3 or 4 not sure which).
Is there anything I can download on to the unit to try and fix this problem, if not I have just wasted £XXX !!!.
Thanks for your help.
Provan
Found this in the manual:
It should be compatible but maybe you have to update firmware of the iPod/iPhone.
Sony ICF-CL75iP is compatible with the following iPod/iPhone products:
iPod:
iPhone:
Notes:
Update your iPod/iPhone to use the latestsoftware beforehand.
iPod shuffle is not available on this unit.
Sony cannot accept responsibility in the event that data recorded to iPod is lost or damaged when using
iPod connected to this unit.
• iPod 4th generation (colour display) cannot play
photo.
