Is there a workaround for transfering images from my SD card on my Sony A7 mk3 to my new ipad pro 2018
the raw image wont load no problems with jpg though.
Hello @bavarian1,
which software do you use to open the RAW-files on your iPad?
Did you try Affinity Photo? With it I had good compatibility with all Sony RAW-formats no matter the camera on desktop - not sure if it will be the same for the iPad version.
- Nic
Thanks Nic I will give it a try
