Unable to register my product
paulove68
Having just bought a camera and lens, I'm unable to register my products. Is anyone else having trouble. I can put in the product code and then nothing else on the page works. Can't click that I didn't buy on line or choose a store. Nothing else works. Help please!
paulove68
Found the solution in an earlier post. thanks for whoever said to search for it rather than put it in yourself
30 REPLIES 30
paulove68
IamNic
Hello @paulove68,
I took the liberty to mark your post as solution.
- Nic
fiocroft
Hello
I too cannot register my product I think for the exact same reason as you. Apparently this is solved, but when I click on go to solution there is nothing there. Can you help? I am trying to get Sony to help but they are not replying.
Thank you
HannahEd01
Community Team
Hi fiocroft, what's the model number of your device? I might be able to help.
fiocroft
The model number is XR55A90J
Does that help? It's crazy I am having this problem!
Thank you
Marino.Manolo
Genius
@fiocroft:
YES
XR-55A90J
NO
XR55A90J
SkyNet404
Specialist
Yea it's really specific, but you need to write the model as it's written on their website exactly, then wait for a drop down to pop up, and you will be able to proceed then. If it accepts the model without the drop down it's not gonna work. Weird really!
profile.country.HU.title
misran05
hey hello i just had some problem how can I register my product
Marino.Manolo
Genius
What kind of product?
