V4 Firmware for Sony NEX5
JulieLimb
I have just bought a Sony NEX5 and have downloaded the Version 4 firmware but still do not have the Peaking Level and Peaking Colour items in the set up, can anyone help me??
First check the firmware version is Version 04: -
  1. Select Menu --> Setup --> Version.
  2. The firmware version is displayed.
If Version 04 is successfully installed, download the manual for the new features - Picture Effect, Peaking Level and Peaking Colour - here: -
http://ids.update.sony.net/DSLR/ErWPkeXQ1r/ver4_manual_gb.pdf
Just remember that to set Peaking to "ON" you must have selected Manual Focus first in the Menu -> Camera -> AF/MF Select.  If you have AF Selected the Peaking Level cannot be activated.
:wink:
:wink:
