Which Polarizing filter
Roger-Burt
I have a Sony A6300 mirrorless camera. Does anyone have a view on which polarizing filter I should use. Circular or Linear?
Thanks.
Roger Burt
ShakeyBluesman
Hi Roger,
Always circular polorisers with auto-focus. You don't get it with linear polarisers
EdwinaU
Moderator
Hi Roger,
You may find some of the suggestions in these shooting tips lessons useful in choosing a filter to suit you.
Best wishes,
Ed
ShakeyBluesman
Hi Roger,
