2015 Bravia Android TV - Can't change digital TV channels
rolandscriven
I have a brand new KDL-43W805C Android TV. I can't change digital tv channels. Analogue is fine.
Numbers or the up and down keys don't work.
Is there a solution/fix?
rolandscriven
Fixed it! - it was related to youview which I can't have anyway - I had started the installation process and as it didn't work thought that was that. However, it turns out it was up but not running. So once I disabled it everything worked!
Thanks very much. Have a good evening.
5 REPLIES 5
Hi there
Silly question - How are you picking up analogue channels?
rolandscriven
Analogue and digital both through a roof antenna. If that is what you meant? I can change channels on analogue fine but not on digital. On diigtal it stays with whatever station I put top in the list. Has been like this since the start. Have restarted etc.
Hey there
What country are you located in?
Also, when you did a restart, did you either unplug the tv or press the power button on the remote control for about 5-10 seconds?
rolandscriven
Thanks for confirming that its fixed.  Have fun.  :thumbsup:
