The message you are trying to access is permanently deleted.
Hi
Google cast stoped working after latest software update. I tried to power reset and storage reset,but it didn't help.
The tv is connected to router via wire. My PC and sony z3 can't find google cast 😞
Anyone?
Solved! Go to Solution.
@Quinnicus wrote:Hi guys
Csn someone test casting. I recieved information from another Expert that its working, as well as @motty79 also saying that its working.
Ps: through tinkering, ive screwed up my cast settings
After manual update of google cast app, it works again.
Thanks a lot.
I still have problems with windows 10 but that is a Microsoft issue i think...
@john.pringle wrote:
How do you manually update google cast. Thanks.
Sent from my iPad
On my TV: Sony Bravia KDL 43W809C it is: Google store - and in the buttom of the menu there was a choice called Updates, but I think it is only there if updates are avalable...
Thanks for your reply I have the x8509 and Inthe list there is no mention of updates Are all these people who are saying Google cast works in the uk It looks like I'll be spending the rest of the day trying to sort it out.
Well it seems you have to wait for the updates to appear on your tv they suddenly appeared so all updated now pleased to report google cast is now working. Thanks to everyone who helped.
Hi.
i am a Danish user. The update was in google store. Now crome/google cast is ok again.
Hopefully the Usb recording and the dual tuner will be available soon.
Hi again, my cast is working with youtube only. I found solutions in polish language Sony forum: please go to system preferences/time&date and choose option-use network time. I hope it helps.
I hate myself because I'm too quick to say things.
Google cast does not work at all on my TV as I thought.
My phone find my TV Google Cast name via apps such as YouTube. But when I want to connect to Google cast, my phone can not connect to Google cast. Google cast version 1.16.45911
For what it's worth, I have a xperia z 2 and KDL-43W755C.
I also have a Cromecast dongle to an other tv and that works perfect.
I have tried to change to network time but do not help.
@Eban65 you are not alone in not getting googlecast to work. i cannot get it to work either from my Z4 tablet - and believe it has never worked even before the update. A couple of others (experts) from other eu forums also cannot get it to work. So i think there is probably another issue at hand here. For the people who had it working before the fw update - its now working.
@Quinnicus wrote:@Eban65 you are not alone in not getting googlecast to work. i cannot get it to work either from my Z4 tablet - and believe it has never worked even before the update. A couple of others (experts) from other eu forums also cannot get it to work. So i think there is probably another issue at hand here. For the people who had it working before the fw update - its now working.
But it worked from when I installed my TV 4/10 until the update 13/10.
Now I have mailed the Sony Support and I hope they will answer soon.
