2019 KD55XG8096 won't connect to hidden wifi network
samikaz
Hello Sony,
I recently purchased this brand new 55-inch KD-55 4K UHD TV (KD-55XG8096) and I love it but it won't connect to a hidden network... only the public ones. I have seen a lot of this issues on previous/older Sony models which were fixed with a FW update.
Could you have a look please.
Regards
Sam
dutchice
Hi Sam,
Welcome to the Sony Online Community!
I do not believe that connecting to hidden Wi-Fi networks is supported by your TV. It is because you are not able to setup a wireless connection manually.
I will have to verify for you whether this is a supported option at all or not. I will update you as soon as I receive more information.
In the meantime can you share more details on what method are you using to setup your wireless connection with the hidden Wi-Fi network and at which step does the process fail?
Cheers,
Dutchice
LightFoot
Specialist
@samikaz wrote:
Hello Sony,
Regards
Sam
Hi @samikaz
Are you able to “unhide” the network and once connected hide it again?
samikaz
Hello Both,
I unhide the SSID and it connects. Then when I hide. it just say SSID is out of range while it is not obviously.
i have the option to connect manually. So I would be surprised it doesn't connect to to hidden SSID specailly as you run android oreo.
Thanks for your time. I will wait for feedback
Regards
Sam
