Wondering whether people could tell me if the TDG-BT500A glasses are in fact the same as TDG-BT400A? I read somewhere that the model number is only different as the 400A's were provided with a TV whereas the 500A's are sold seperately.
Also, any other glasses that are compatible without the huge price tag? Can't really afford £250 at once for glasses to keep everyone happy!
Thanks for reading
Hi there
Please see the following two threads, as this will answer you questioms.
https://community.sony.co.uk/t5/televisions/3d-glasses-for-the-kdl-43w805c/td-p/1962772
https://community.sony.co.uk/t5/televisions/3d-glasses/td-p/2048470
Thanks for your reply. I eventually found some on good old eBay which are listed as working with the TV I have. They are Sintron 3D RF Active Glasses (should anyone else happen across this thread).
I'll post back once received and advise if they work.
I bought some samsung ones ssg p51002 , twin pack for £17.99 Currys, just bought another pack from amaxon for £15. Work fine on my new 55 android tv.
Just to confirm, the Sintron glasses work perfectly
