43xd8305 and ir blaster and sky hd
Johnwithsony
The remote jumps 3 items up and down on the sky menu when u press remote once. Done factory reset and to says it's up to date . How can it be fixed ta
8 REPLIES 8
Hi there
Can you tell me what firmware version your TV is on please - as this problem was resolved previously.
Edit:
Linking to this thread:
https://community.sony.co.uk/t5/android-tv/43xd8099-ir-blaster-problems/m-p/2240306
Johnwithsony
PKG 6.0514.0001 EUA
Hi there
Thanks for that.  I have reported this to Sony, as from the description it appears that an old bug that was previously resolved has been re-introduced in the marshmallow update that was released on the 27th September.
Previous Resolved issue:
https://community.sony.co.uk/t5/televisions/2015-android-tv-bugs-and-issues/m-p/2040428#M34639
Wask11
Same problem here... 55XD8005
Hi All
I have re-opened this bug/issue, see:
https://community.sony.co.uk/t5/android-tv/2015-android-tv-bugs-and-issues/m-p/2040428#M54
Johnwithsony
This is still an issue even after latest update. What is happening about this issue. Thnx
Johnwithsony
And I am still in waiting for an answer.
Hi
Which answer would you like
  1. It is not fixed
  2. Sony is aware of the issue
  3. It is unknown when a fix will be available
  4. Any information will be posted : HERE
  5. All of the above.
