49x8309c
howarda15
49x8309c
Hi
My tv keeps saying my Google play music has stopped working, or my google play games has stopped working, or my google play store has stopped working. HELP!
Thanks Howard
LightFoot
Specialist
@howarda15 wrote:
Hi
Thanks Howard
Hi @howarda15. If I was you I would start with a soft reset (hold down the power button on your remote until it performs a soft reboot).
LightFoot
Specialist
@howarda15 wrote:
Hi
Thanks Howard
howarda15
Thanks very much, it has worked so far
Howarda15
