Recently I upgraded my old Sony TV and replaced it by 2016 49XD8005..
I do have oldest home cinema / DVD Sony DAV-DZ260. I use it just for speakers.
My new TV is having one little problem with volume control over HDMI CEC.
Hi there
Instead of decreasing the volume down to 0 value. What happens when you press the mute button? Just trying to find a simple alternative.
yup it works...but all other remote hdmi commands works fine from TV. Even "decrease volume" works fine as long as the volume was increased via TV. "Decrease volume" stop working once the DVD volume is reached...like the volume level which was set on DVD after poweron or which was set by DVD remote controller. Such a volume is considered by TV as volume 0. It is not handy as you power on the TV by TV controller, sounds goes up, but somebody was having high volume previously...at the end I need to search for DVD controller and decrease volume through it...Since this I can control the volume via TV without any limits.
I would understand that the HDMI CEC doesn't work at all...but I don't understand why everything works except one thing.
Unfortunatelly I didn't test the behavior prior android 6 upgrade 😞
Thanks,
Petr
