49XE9005 MotionFlow (2.40:1 - judder)
profile.country.SK.title
TheAndrew
Hi all, I have MotionFlow issues on aspect ratios other than 16:9. Please, how can i fix it? Do I have to buy another device like nVidia Shield for smooth playback? For example, a lot of movies are in 2.40:1.
thanks.
5 REPLIES 5
profile.country.AT.title
Kuschelmonschter
Hero
You should do a search. There are some threads already dealing with it.
TheAndrew
Thank you for your answer. I found some threads here and on german forum but without any solution. I am already tired with the issue. Should I have to buy new device or can we expect solution from SONY (new firmware)?
Kuschelmonschter
Hero
Sony has been ignoring most issues the past few years. Don't expect anything from them.
TheAndrew
Is that issue with my TV? or we can meet "2.40:1 - judder" on every Sony Android TV.
thanks.
lollypop11
It is not your TV only. the best thing would be a buy a external device like apple tv or shield tv and you are sorted.
