4k TV HDR KD-XD8505(KD-XD8588) issue !
Iavkataz
Hello,
 I got the mentioned TV which is connected to XboX One S . I tried all the settings off/on and nothing happens.There are threads to turn off the advanced contras setting / eco mode and etc. The screen continues to dims and brighten up at random.
 Please help.
Iavkataz
i think i found it. Exclusion method ! on the xbox there's an option colour depth - PC RGB .. i thought sony 4k hdr tv support it but with it the TV went "nuts" .
4 REPLIES 4
Iavkataz
Thanks in advance,guys!
Hi there
Without knowing all your settings, its hard to know where to advise.  I can only suggest the following:
  • Ensure Game Mode is activated
  • Ensure all ECO settings are OFF
  • Ensure Light Sensor is OFF
  • Turn OFF Black Adjust
  • Turn OFF Adv.Constrast Enhancer
  • Turn OFF Live Colour
  • Turn OFF Reality Creation
  • Turn OFF MotionFlow
Iavkataz
Cool - glad you found it :slight_smile:
