55XD8599 Problem with 4k channels
johnmorra
Hello, I have a problem with my TV basically with 4k channels. I've tried to change all the options but it doesn't help.
The problem is that when I change channels and go into some 4K, the image gets much much darker. It is really annoying, because even the menu options are then blocked on these channels. I tried it with IPTV as well as normal digital TV ... HDR mode is enabled.
Any ideas?
rooobb
which "normal digital tv" channel offer 4K? it may depend on the broadcast in any case (as it does with some sky q transmission)
